m3 2.3L to turbo?
05Mazda3sp23
2005 Mazda 3 SP23 Sedan
ok i looked around and have not found much info so just want some input... im looking at turboing/ turbo kits for my (daily driver) 05 mazda 3 sp23 sedan with slip/auto(tranny)... just wana know some basics like what i would need to do to the car(besides whats in a basic kit)... new tranny? fuel pump?...others...and im looking at maybe 6psi and also any places to find/buy turbo kits... also anything negative about doing this?
sorry for all the Q's
Thanks for the help
Tri-Point engineering, and even an auto should be able to handle 6psi. Keep it under 200 hp (I've read) and you should be OK.
thanks... so i can run stock fuel system... and stuff... also the tri-point turbo kit has a stand alone, which would i need? and its manual only
I am hardly the turbo expert, but when low-boosting, probably.
Besides, IIRC the Tri-Point comes complete and I hear their TS/CS is excellent. You should ask them before purchase.
haha im surprised rich. youre handling this fairly well i must say. ;) you should nag the wife some more about a turbo :P
I have read a lot from people that have or installed turbos and companies that sell them, but again, no personal experience. Many of the specifics of it all are still a mystery to me.
And no, after 7 yrs (in August) with this car, what would be the point of spending several thousand dollars and god knows how many trips to a tuning shop to get everything right. Then be required to run 91-93 oct fuel all for my DD.... not that it wouldn't be fun to be boosted. Its just not practical at this point for me.
see i like this/ these reply... makes me really think and dig up info before doing it... and may or may not want to turbo lol
I would recommend doing a lot of research before doing anything. At least then if it doesn't work out the way you expected, you would have done everything you could to make it happen.
A turbo is a big jump, IMO. It takes some commitment, both during the initial install/tuning process and then later on a day-to-day basis, such as running higher octane fuel regularly.
But any time you put on hp/tq adders, you run the risk of making something else on the car wear out (or break) that much faster. CV joints/axle shafts for example. Clutches, bearing and in your case putting more strain on the internals of your auto trans. Etc....
running higher oct is not bad because i do that now... but i have been looking into this for a few months now... the biggest thing is can the car handle it aka(auto tranny) and ecu maybe
Thanks for the help
You can look at are Reative Racing, build your own, GP-werks and Tri-point. Their are alot of old used kits members are welling so check them out as well. The 2.3 motor can handle 7-8psi as a daily driver but anymore and you will likely go boom. :) If you plan on boosting I would recommend upgrading your clutch. The stock tranny should be fine at the recommended psi on a MTX but on ATX......boom boom boom.
