Low speed
Blue, 01, MP3. -> Yellow, 03.5, MSP
Anyone found that the car can rock back and forth when you are driving at a low speed? This problem is getting less annoying after I get used to the gas + clutch release and throttle point.
But My friend's SI(R) and my brother's Sentra does'nt have the same problem. Is that just the protege or just me?
uhh you sure it's the car and not the driver? my feel is that it all depends how you play with the clutch and gas. if I nail it right it doesn't but in other cases if I let go to fast obviously it does it.
if it only dose it when you shift, that means that you drive to fast and shift to slow :p , (
Our trans is set up fo fast take off's, like parking lots if at low speeds the car rocs back and forth. so put the car in second gear, problem solved. S-10's have thesame problem. but there setup is for towing. not speed. You can drive slow at 5mph in 2nd gear. later.
