ihaveworms
- CX-5
I have had squeaking sounds coming from the trunk area of our 2016 CX-5 for a few years now. I took off some plastic panels and found a nut had fallen off one of the bolts, so I put on a little loctite and replaced that nut. Still squeaking... I have been putting it off to look into it further until today. So I opened the trunk and took out these plastic plugs over two bolts (left and right side). Both of these areas appear to have a missing nut. I don't know for certain if there is supposed to be a nut here, but I would assume there would be.
So I was hoping one of you all could verify if there is supposed to be a nut here and if so, what kind of size should I look for for a replacement.
