glyph said:i had a similar issue where my screw had backed all the way out, but hadn't fallen off yet. I wonder if I should move my MAP. I have it hooked up to that line with my cruise control. Do you have the vacuum source from Beau?
Also, please describe "better": smoother? response?
The M300 sounds like a better buy overall just because of the data logging.
It reacts much faster to changes in AFR than other widebands I've seen.. it is very key for accurately seeing what happens during throttle pumps and so forth and seeing if a misfire is you going rich or going lean... important things...
