License plate bulb size?
dmx3118
2003 mazda protege5
I am changing most of the lighting on my p5 to led lights and i am having an issue finding the proper sized bulb for the license plate lights. i was using the sylvania replacement guide, which seems to have been accurate with most of the bulbs but for the license plate light it says it is a 3652 and i cant seem to find that bulb anywhere.
i was going to be ordering the leds from autolumination.com and they dont have the size listed any help would be great.
also the sylvania site list there being a tail light and stop light(if they are the same i assume i am ordering a red bulb due to the lens being red correct) i assume these are the same thing. they do the same for the side marker and parking light or front turning signal and parking light, again i assume they are the same.
cheese helmet....i assume that is a stock replacement right? i wanted to do a led replacement
and ctt that link is not working what is it to
Weird, it was working earlier. Check out sylvania.com. They have an automotive section that includes a replacement guide for all applicable bulbs. As for LED, just find which one relates to the bulb you want to replace. IIRC the license plate bulb is 3652.
thanks everyone for the help i was thinking 194's would work i just didnt want to buy them and have them not fit
the 194's work (i have LEDs too)
but I was able to get the passenger side like socket out, but the drivers side feel like the wire behind it is too short to get the cover off or something. I get it all unclipped from the body but then I can get it far enough out to get the cover out.
