length of wire??
boomboom
does anyone here know what the length of wire should be going from the battery to the behind the back seat including going through the fire wall and along the side with alittle extra???:confused:
are you going to run the wire through the driver's or passenger side? driver's side would probably only need about 15 feet, probably less.
yeah iam going from the driver side its easier becuase the battery is on that side. iam at work and going to order some wire so iam not able to measure right now.
Your best bet is to get 20 feet. You are better off with too much than too little. But cut it so you don't have too much excess wire when you get the thing mounted.
yeah i know that i install stereos all the time but didnt have time to measure the length. but i got it now so thanks anyways
