do you have a fmis or smic? if you have the smic could you take a pic of the bay so i can see how you connected the outlet of the rdv to the air intake pipe?
an someone please tell me the inlet/outlet size of the stock BPV? I'm wondering if I could match it up to work with this Dual Port BOV
http://www.turbosmartonline.com/index.php?id=48
505 Zoom, I know you test stuff for Boostsciences, do you know of any other way to contact them other than email? I ordered my RDV last wednesday and havent received any correspondance other than my paypal receipt. I have emailed them about the status of the order but I havent heard anything back yet. They are still in business right?
perfect! it seems as though this replaces the stock BPV (it fits in same location, but also vents 50% to atmosphere) - correct? Do the lines that go into the stock BPV and out of the Stock BPV fit onto the 20mm inlet/outlet of the turbosmart valve that you have? in other words, are the boost inlet and outlet lines for the stock BPV 20mm???
You guys that are using a 50/50 valve are missing the point. You need a larger vent, and a 50/50 valve won't give it to you. It's not about venting half and recirculating half... it is all about creating a larger path.
had a strange one happen to me a few days ago.
with only a cone filter on the OEM piping and intake with OEM BPV, i had a leak.. but that leak would make the OEM bpv go woooosh. when i found and fixed the leak.. turkey was back. the leak was , get this : the drain bolt on the OEM SMIC.. it fell off by itself.
my theory is that if you get a fitting to screw into the place of the bolt, and then you install a bpv on the fitting and you got a dual bpv setup, one on the pipes and one on the SMIC.. and no more turky and a whoosh.
i know it sounds ghetto but it isin't that bad..
