This has got to be one of the quickest build threads I've seen. Good work buddy!
Thanks mang! I don't mess around!
The OEM mounts appeared to be in decent condition still. No cracks or dry rott or anything. And I hosed the EGR valve out with throttle body cleaner before installing the manifold, but maybe I didn't do a good enough job?
I tapped into my radio harness since I installed an aftermarket head-unit. It was pretty easy since the radio harness wires were labeled; I just soldered the constant 12v, acc/ign 12v, and ground wires from the gauges I'm running to make it's own harness then used T-Taps to connect them to the according radio harness wires. So my gauges go on when the radio is on
If you need more info let me know, unless someone else recommends doing it differently.
Congrats Josh! Engine bay does look good...I see you opted to keep the ForceFed vc and installed Evan's header. And those headlights look fantastic! Sux about the CDM lights...that was one helluva bargain...damn UPS.
