So it's been way too long since I updated this thread. There has been little significant progress but things will be turning around here shortly. There were a couple of things that got done in the last 3 months with the car.
Pulled engine
Removed AC
I've also been collecting even more parts. Just to name a few: All 4 AWR mounts, Medieval PS pulley
CR3 Provided: Custom ADP, Custom Wiseco 8.8:1 .020 over, ARP Head studs, ARP Main studs, Cometic Headgasket
I still have to get the following parts before I can start my engine build: Complete gasket set, bearing set, timing kit, cam/crank output seals, oil pump, water pump, valve seals, and some others.
I'll try and keep this updated a little better and get some pictures up as well.
