After i lost 1 1/2 motors, i'm kinda scared of my car and running very rich and pulling alot of timing. I'm boosting about 15psi and the car feels slower than it used to (because of fuel and timing i assume).
I attached a screenshot of my WOT ignition setting from my MPI. With the J&S in the loop, could i safely add a few degrees to my ignition map relying on the J&S to pull some if need be? Just wondering how you guys use your J&S to maximize power without pulling too much timing
Eventually, i'll go for a drive with someone and my laptop and keep adding timing until the J&S' led starts to light up and then pull 1 degree and leave it like that.
