is this the correct exhaust?
Who is to tell if the ENTIRE exhaust system is 2" though, it technically can't be, there is a part somewhere that is bigger, it may have just been the pipe exiting the canister on the rear which is why with better pics nobody knows...
Yeah. Lol. That's true. But if the tip is only 2", and the rest of the piping could be up to OEM spec, would it not bottleneck the exhaust?
Unless a quarter of an inch wouldn't matter that much.
I doubt that would happen...definitely not enough pressure...if that were the case, then you could put a tennis ball in the exhaust and literally shoot it out like a cannon...
heres some more underneath pics of the exhaust, if this helps any to see if it is a oem exhaust. that whole tailpiece looks like its all one piece up to the muffler.
OK, I have measured my cut off oem tailpipe, cut off just behind the muffler and the actual tubing is less than 2" OD... closer to 1-7/8"
There is a sleeve with the OE tip spot welded to it, that is in turn welded to the the exhaust tubing that is slightly bigger. Approx 2-1/8" OD.
The OD of the stainless steel tip itself is 3".
Now, if everyone looks at the last picture, you can see that the tailpipe on this car is an aftermarket unit by the label that is still visible. Obvoiusly someone installed a parts store system but for what reason remains to be seen.
Hi everyone,
Exhaust is something that is talked about heavily in my area of the car world (that being the Datsun 510 where almost everything is custom made). 1 7/8's sounds about right for stock exhaust. Look at big power house cars like my buddies Acura TL-S (350hp if I remember correctly) and you will see the pipe size if WAY smaller than one might think. This is to keep low end torque strong. Increasing pipe size will lower low end torque but free up flow giving you high end hp increase. It's not a huge change but it is a change.
Also, theoretically, if the exhaust was 2.5 inches and the tip was 2.0 you could launch a tennis ball out farther than a 2.0 inch system all the way back! :) The area behind the blockage is what would determine the amount of pressure built. The larger diameter behind the tennis ball would allow a greater volume of air to compress and consequently a greater volume of air wanting to escape. Think of it as add more gun powder behind a cannon ball. My dad used to tell me stories about when he was a kid and would stuff tomatoes and potatoes in peoples tail pipes in parking lots and watch them start their car up. The cars would stumble and they would rev it up and the fruits and veggies went flying! :)
That 2005 Mazda3 came with two different OE systems, split system and a single piece system, You could buy the factory tip from the split system and have it welded on. The piece isn't cheap though. Dealer list is 111.44, dealer cost is 66.85. I sell it to forum members at 76.88 plus shipping.
ALSO! The OE split system DOES use clamps like a muffler shop as indicated in the picture below which came from our factory catalog. The main difference is the aftermarket kits, like from napa, save on price by not adding things like a nice expensive tip.
Hope this helps,
Chris
Autotown Mazda
