Is this a good Turbocharger for the 02 Protege5?
Khoifather
Mazda Protege5
It comes with
Protege Extreme Turbo Kits Include:
- Garrett T25 Turbo w/ Wastegate
- Cast Exhaust Manifold
- Chrome Heat Shield
- Downpipe w/ Gasket
- Map Unit (Black Box)
- 2 Injectors & Interface Block
- Injection Control Unit w/ Turbo Timer
- Blow Off Valve (BOV)
- High Flow Front-Mount Intercooler
- Polished Aluminum Intercooler Piping
- SS Braided lines for Water Cooling
- SS Braided lines for Oiling
- Return Hose and Fittings for Oil to Pan
- All Hoses & Clamps
- All Necessary Hardware & Fittings
- Generic Install Instructions
- Injector Control System Settings
For Engines: ZMD (1.6L), FSD (1.8L & 2.0L)
Boost: 6 PSI
HP Gain: 56% Increase (safely on stock engine)
Turbo Efficiency: 300+ HP
Direct Bolt-On: Yes
Warranty: 5 Year on Cast, 1 Year Accessories
Ball Bearing Upgrade: $400.00
Total cost is $2799.99. Is that worth getting?
FunkyBuddha said:
Pictures of the kit would help. Who makes it?
The brand is TSI and here's the picture
Turbo Matty P said:
yeah not bad...I bet it's better than a stock MSP setup even though it uses the same turbo.
How much you think I would be pushing to the wheels with this bad boy?
doesnt turbo screw up the reliability of your car?....i heard it decreases your engine's reliability and longevity
i would get one if i knew that my car would be just as reliable as before
jjac28 said:
doesnt turbo screw up the reliability of your car?....i heard it decreases your engine's reliability .
that all depends on how well the kit is tuned
I have a 1986 Chrysler Laser with a stock non intercooled T3 turbo setup
it has more than 140000 miles on it and it still runs well
my brother has a Flyin protege kit with 7000 miles on it, the only trouble he had was when HE turned up the boost to 11psi and took it down the track
I'd venture to say about 130-140whp. I say this because that's what stock MSP's are putting down and you're using basically the MSP turbo set-up with a better intercooler. Don't expect huge gains, but you will get a more interesting car to drive!
Hmmm... Sounds Like A Good Kit, But No Matter How "safe" They Say A Turbo Kit Is For A Stock Engine, You Always Are Better Off Building Up The Internals A Little.... It's Well Worth It To Avoid Problems, And Might End Up Costing You Less Than Rebuilding The Damn Engine When You Blow It...
Hey im looking at getting this in the near future for my 02 p5, have you already installed it? And if so how is it working for you? Would you recomend getting this or a different kit? Thanks I appreciate the help.
