Is there a way to bypass clutch switch
02 Mazda P5
I have trouble sometimes starting the car. Turns out my switch is going bad, checked with a meter and i would go no resistence at times. Is there anyway to bypass the switch for the mean time till i get the funds to get a new switch.
protege5
i wouldn't recommend it, it is there for a reason. but if you were stuck and couldn't get home, you could just use a scotch lok or even a paper clip and short the wires together. but really, i can't imagine a switch is that expensive? they're all over online for about 15 bucks
pcb
The Diagram Dude
2002 MP5
The ECU monitors the clutch switch activity.
It needs to know when to go to idle.
You'll throw a code if you bypass it.
