Z zbillster Member Nov 21, 2002 #1 My clutch pedal sits rather high (noticably higher than the brake pedal). Is there an adjustment for pedal height (like my CRX has)?
N njaremka Wiggity-Wack-O-Tack Contributor : 2019 Mini F60 JCW Nov 21, 2002 #2 yes, just make sure you have enough travel to disengage it:
J JasonH Member Nov 21, 2002 #3 It looks like if you used a longer adjustment bolt (B) you should be able to adjust out close to 3 inches of pedal stroke while leaving the disengagement stroke intact.
