Micaspeed1
- 2003 MSP Black Mica
Well something went wrong. I was around 4500rpm in first gear and pushed in the clutch and heard a pop. Then no responce from the clutch when i put it in second. At first there was a slipping noise that kind of sounded like a spinning clutch but after i parked it there was no noise at all when i engaged / disengaged the clutch and no forward or backward motion either.
Here is where i am thinking it is the LSD. When i put it in first gear and release the clutch the motor dips a couple of rpm like it is spinning the tranny. when i put it in fifth gear and try to move forward it bogs the engine down even more when i let the clutch out, like it is spinning the gears. Then when i put it in reverse it makes the usual reverse gear sound like a faint rearrrrrrrrr. All this and no car movement.
Is there a deffinate way to tell it is the LSD or clutch without dissassembly?
Either way Im going for a full engine, clutch and maybe LSD rebuild now that i have to tear it down. Thanks for any tips help in diagnosis...
