i have a 07 speed 3 sport and i bought a aux cable to connect my ipod.
but when i went to connect it nothing happens
i've tried everything
what can possibly be wrong? any suggestions?
btw i have the newest ipod nano i believe it's the 8th generation
thanks
do you have sirius?
turn up the volume to max on your ipod?
refer to driver's manual if that doesn't work.
When you push MEDIA does the HU LCD switch to media mode or does it not switch from the current setting?
it doesnt switch from it's current setting
So it doesn't say "AUX" in the display? Have you tried hitting "Mode" on the steering wheel?
If it's not switching then it's likely that the ACI isn't actually plugged into the back of the HU. It's possible that the previous owner had sirius and it never got plugged back in. I suggest you pull the HU and see if it's plugged in, and if not plug it back in and try again. It's likely either tucked behind a panel or tied off to another harness to keep from rattling.
the newest nano is the 4th gen btw
yea i've actually heard this before. is it hard to remove the HU?
