I check the battery and alternator, and the voltages are all fine. The car Start 98% of the time like normal. But once in a while I get a no-crank or an weak cranking; and then cycle the ignition a few times and it start normally. I bought a new starter, which I'll install. But I am wondering if it might be relay within the alarm (hence the clicking/buzz from under the dash). I'm gonna switch out the starter this weekend, and if that doesn't solve the problem, I'm going to take out the alarm (which I hate anyway). Anyone else had a similar problem? Just thought I would check and see if anyone has gone down this path before.
