As long as you never remove that solenoid, then it won't ever pop a CEL. Those things can very easily be put out of the vacuum loop. However, to use the stock vacuum solenoid, you'd have to cut the connector and put a resistor or somesuch between the ECU side wires, so it didn't pop a CEL, but still let you control the solenoid itself by wiring the control switch to the VICS solenoid. Generally, this can be done with an RPM switch ala MSD or a VTEC/V-anything controller of some sort. I'm sure you could wire some sort of trimmer inline, too, to act sort of like a relay; Once the trimmer's threshold had been breached, it would trigger a relay that turns the solenoid on... Lots of different ways you can do it, in other words. =)
