kudos for that!
1. drain coolant, you will find a knob at the bottom of the radiator.
2. remove top hose, not completely just the radiator side.
3. remove coolant bottle hose. the one next to the radiator cap
4. remove fans. remove the wiring clip. 2 10mm screws on top of each fan hold it in place. remove bolts and pull up.
5. remove bottom radiator hose. you will need to get under the car. careful, there may be coolant inside
6. 4 10mm screws hold the radiator in place. two on each side. top side near the headlights.
7. remove radiator.
P.S. if you have the stock intake, that will need to be removed prior to step one
p.m. me if you need any help
