- MP5T / 944
Get TEIN-SS
Then you can set it to whatever you want..
Brian MP5T said:Get TEIN-SS
srd555 said:I had all the same negative experiences when I had the sportline/ illuminas. I tried all the shock settings and still was not happy. I gave up and went with the KW coilovers. They are 340 lb/in in the front and a progressive rate in the rear. The ride is firm but not stiff, maybe like setting 1 or 2 on the illuminas when driven normally. When pushed the shocks seem to get stiffer (dunno) so it always feels perfect.
It still has a little bump steer but its less than the sportline combo I had.
I am finally happy.
Yeah, I thought I was going crazy too, because when I came on here everyone said it was the geatest setup they ever had. I think the problem was the shock valving. If you set it to were it was comfortable to drive @ up to 4/10ths, then it was very squirmy/bouncy @ > 5/10ths. Mine for instance was set @ 2 front 4 rear with 36psi in the front tires and 30psi in the rear. This set up felt comfortable on the street and gave the best turn-in response (almost an oversteer) in the first half of a corner, the second half would have a balanced feel. This same setup however, would have a squirmy/bouncy/wandering feel when driven at or above highway speeds especially when you hit multiple bumps with high frequencies, eg. expansion slots on a bridge. When I upped the front shocks to 3, the car did not want to turn and the front wheels would skip over bumps.MrDiggler said:I'm glad to know I'm not alone here. I was starting to think I was crazy because I never would have guessed I wouldn't be happy with this combo. I finally got to take my favorite off ramp tonight and I'm not sure that I'm any faster around it than before. There's a bit more drama now, as the suspension doesn't ever fully settle down like before. It seemed to keep squirming/wiggling above 8/10ths of the limit.
Could you ever hear your Illuminas? Ever since mine have been on, I hear a squish noise or high pitched whoosh from the right rear on any significant compression.
Yes, both the illuminas and the KW make that whoosh sound. I herd mine from all four corners though.MrDiggler said:Could you ever hear your Illuminas? Ever since mine have been on, I hear a squish noise or high pitched whoosh from the right rear on any significant compression.
MrDiggler said:Still haven't switched out the combo. Thought I'd give it a fair shake, and I'm honestly not 100% sure what I want to do yet. I'll probably put the stock setup back in, but I'm really getting used to the look of it sitting 2" lower!
That said, I'm still not too enthused with this combo. I still think it rides like s***, and I don't think it handles any better than before.
MrDiggler said:Thanks for the info. So, my front being lower might have a lot to do with why I'm not happy with the non-linear turn-in, etc.? Are the Megans too stiff for HP struts? Any pics of the stance after the install?
MrDiggler said:There's no email address I could find for them, but I just got off the phone with Ray at Tokico in L.A. Apparently he was involved with the suspension testing on these cars a few years ago, and he said that the HP would correlate to about a 1.5 setting on the Illumina (for those who don't know, you have to set them in increments of 1). This also means they do overlap a bit with the HP. At least I have a reputable reference point now, and with my most recent Illumina settings in the 1-2 range, it would appear that my ride quality problems are not due to big differences in the struts. On that note, he also went on to say that they noticed that the MSP in particular didn't take well to being lowered too much and street driven, at least with their struts, because the ride quality deteriorated severely. He indicated that to maintain a decent ride quality and handling feel on the street, the MSP needs to keep as much of its suspension travel as possible. I'm sure this holds true in general for most cars, but it was surprising how distinctly he seemed to remember how the MSP behaved during their testing, so it apparently made an impression.
Either way, I'm glad for the info, and will probably keep my Illuminas, and therefore keep some adjustability. Now I just need to find a set of springs to my liking, and I bet they don't exist. I'd like something with the design and spring rate exactly like the Racing Beats, only with the front .75" lower than the RB when compressed.
jmv said:For whatever difference it makes, the megan racing springs are stiff but don't drop the car as much as the goldlines, as CustomMSP pointed out. My friend got some iluminas and megan racing springs on his P5, with the struts set to 4 in front and 3 in back, the ride i went on didn't feel any worse than my stock setup. But of course i'm not as familiar with it as someone who drives the setup every day.
MrDiggler said:I've thought about it, but I'd be cutting off the flat-wound load bearing part of the spring to do it, and that worries me. If I knew for sure it wouldn't be a problem, I'd go for trimming them just a bit.
CustomMSP said:All of the aftermarket springs I've seen do not have a flattened out top coil.
