Hi,  The problem is that after taking apart everything to get to the manifold to take it off ,I ended up not removing it so put everything back together for some reason the car doesn't idle properly and dies ,any ideas where to start should I scan with OB11 scanner ,would that show anything .Thanks Alex
Better tell you that the manifold was loosened but did not take completely off ,just tightened up nuts with old gasket,,, would I have had to replace it. Thanks ,,,,,,, Gasket that is
