P0504 Issue – Brake Switch Signals A/B Correlation
Good evening everyone, I own a 2020 Mazda2 Skyactiv-G 90 Mild Hybrid Evolve. There aren’t many of them around in my area, so as soon as I saw the first opportunity and listing, I immediately bought it from a private seller.
The car had—and still has—a problem related to the brake/light switch sensor. The seller had already contacted the only authorized Mazda service center in the area to resolve the issue, namely a non-original sensor that was causing a compatibility error. He reassured me that it would be a simple fix and that he would pay for the part himself after the sale, once it was replaced. Naively and without asking too many questions, I went ahead and bought the car.
I’m here because the story didn’t end well: replacing the part (€100) did not solve the problem, and Mazda quoted me €450 just for analysis and investigation of the possible cause (according to them, a wiring issue).
I’ll explain the problem scenario:
The car works normally—it brakes, the brake lights come on, everything seems fine. After a few braking events, randomly, three warning lights appear: the engine light, the triangle warning (generic problem), and the anti-collision system (SCBS deactivated).
Over the past few months I’ve researched the issue, studied manuals, wiring diagrams, and other material to try to understand the source of the problem. I bought an OBD2 device and learned how to use FORScan to read brake/light sensor signals, voltages, and other data, but everything seems normal (if you want, I can share these readings).
I’m coming to the conclusion that it might be a damaged or corroded ground connection of the BCM, which intermittently alters the signal and therefore not constantly.
I’d like to ask if any of you have had similar issues with this sensor or with other sensors.
If you want, I can also attach the error readings so I can provide the exact fault codes.
Thank you for your attention:)
I had a very similar issue with my 2016 Mazda 2 1.5 Skyactiv. I had an engine management light related to the brake switch and decided to replace it myself.
In my case the problem wasn’t wiring but how the switch was fitted. I installed it with the brake pedal held down instead of fully released, so the self-adjusting plunger wasn’t in the correct position when I locked it in place. That confused the ECU and caused the number plate lights and the offside position lamp to come on with brake input, and the cruise control to cancel when the headlights were turned on.
At the time I didn’t realise I’d fitted it incorrectly, as the engine management light initially stayed off. However, the triangle warning (generic fault) and the anti-collision system (SCBS) warnings kept returning. About a week later the engine management light came back on with the P0504 code for Brake Switch A/B Correlation which led me to do more research and realise I had fitted the brake switch incorrectly.
Did the seller give you a receipt for the work? If the brake switch was replaced, it’s possible the plunger wasn’t seated correctly when it was fitted.
I spoke to Mazda UK at the time and all they offered was booking the car in and charging for diagnostics.
Thanks @James11 for the reply.
After removing a few panels on the pedal side to check the ground point, I concluded that the grounds are fine. By further studying the car’s behavior, I noticed two things.
The first is that after resetting the errors, before the warning lights and faults reappear, the cruise control cannot be activated. The second thing is that the errors show up after 5 or 6 braking actions, which makes me think that the control unit triggers the faults after a few incorrect readings from the sensor.
The only thing left for me to do is try removing and reinstalling the brake switch sensor as you suggested. It seems strange to me because the work was done by an authorized Mazda workshop.
