I want to buy a WB02
WShade
Contributor
'05 Subaru WRX - Red
I want a wideband unit (not just a gauge), which one are you guys using with prices. Thanks.
Uego 1000. Got it for $500 in the group buy.
Works nice. Could be better looking, but I think that can be fixed with a new dispay (that's on my list, but near the bottom).
The WBO2 is a great thing to have.
I'm happy w/ my Uego so far. Beavis - did you mount yours where mine is mounted?
I also have the Uego from the group buy. Very nice tool. I have mine mounted above my radio in my pocket.
WShade said:
You guys have any pictures and who did you buy it from?
You've come to the right place :D
The ueg is only $550 now I think, from Spoolin ITS.
Here is my display of it, and the guys at BEGI welded the bung for me whic works fine except is a bit to high.
look at the ash tray!
1st MP3 in NH said:
Is it possible for you to show me a different angle of this picture? How far does it stick out? What did you use to cut the hole? Is the display removeable?
The display does not stick out, it is flushed with the top of te ash tray, the bottom ofcoarse must fallow.
I gut the hole with a drill and airsaw tehn cleaned it up with a dremel and file.
wow...the innovate ones is CHEAP....$349...sensor, computer cable, CD, Manual...wow! anyone have any experience with it?
The LM-1 is a pretty nice unit. The circutry is all digital and compact, which is why it is so cheap. The wideband sensor it uses is a Bosch LSU 4.2 which can be had for about $35 shipped which makes it a very friendly price for replacment (100k miles).
The LM-1 itself can store 44 minutes of datalogs and has the option for 6 different inputs and 2 outputs. The customer service from the guys over at innovate is top notch and they have helped me with a few of the problems I've run into with the unit.
It is also flash upgradeable for future enhancmeents and works with both NTK and Bosch sensors. All of this info is available on their website as well.
I would recommend buying an extra set of cables for anyone wanting a permanent attachment.
Sorry WShade,
I did call you the other day, but I was driving and had to hang up. I'll give you a call.
Good choice, I've been in contact with Cort over there and he takes great care of his customers! I've been working with them on firmware updates and different bug fixes here and there.. overall a great unit for the money! I can't wait till the RPM input and the remote display come out.
If you find out before me when the updates and additional options are available, please let me know:cool:
For those of you using the Innovate LM1, how are you pulling in RPMs? I've recently picked one up... works great. The tach accessory isn't available yet, though, and I've tried unsuccessfully to get an LM2907-based freq-voltage converter to work. I basically can't get the damn thing to interface to a tach signal. Works great on the bench.
I also found out that Innovate dicked up their Aux In pinout in the manual. :mad:
