nvmsp said:So say i wanted to relocate the MAF with my HiBoost pipes. What would I need to do in order to make everything work without running into issues like stuff not fitting right etc. ???
naw... just a little farther from the MAF then where it is should be fine... that way the air isn't being sucked out through the MAF still.smo0f said:yeah, it is recommended that you move/put your bov on the hotpipe
smo0f said:Actually, you say that air gets recirculated or blown off whether you have a bov or bpv before it reaches the throttle body. It doesn't. The air that's recirc'd or blown off is air that has hit the TB when it shut and flows back. The reason why there's hesistation/stumbling is because of the turbulence caused by this that affects the next 'batch' of air that was read by the MAF as it hits the air exiting. Something like that. At least that's what makes sense to me.
