jsahyoun said:2.75 Inch
RenzoMSP said:So does it hesitate more than before you relocated?
vxfilmer1000 said:Well before i was on 10psi it hesitated like it does now but before i relocated and while i was on 10psi it didnt hesitate...
Matrix said:Wow, I'm stumped.
Are you double checking for boost leaks, etc.? Maybe try switching to t-bolt clamps instead of worm clamps.
This is weird, I think you're the only case I've heard of where hesitation persisted after MAF relocation.
Matrix said:In your pics, it looks to me like they're more than 3 inches apart.
srvntfhim said:I'm not all that educated about relocation, but doesn't everyone usually run the bov AFTER the MAF??
Matrix said:Nope.
In the stock setup, the problem is that the BPV is located after the MAF and before the throttle body. The MAF measures a certain amount of air entering the intake. The engine thinks it's going to get that air, but it gets recirculated instead of making it past the throttle body and into the intake manifold. This causes slight hesitation and not-so-great gas mileage because the car is running unnecessarily rich (extra fuel is injected for air that didn't make it to the combustion chamber). When the MAF is relocated to after the BPV/BOV, the engine reads only air that is getting to the throttle body, not measuring air that is vented between shifts. Thus, a more accurate air/fuel ratio is maintained resulting in better fuel mileage and less/no hesitation or stumbling.
vxfilmer1000 said:So you guys think these would work alot better and "possibly" solve my problem http://www.siliconeintakes.com/product/000055.htm
srvntfhim said:AND some t-bolt clamps
Matrix said:If you are 100% sure that your pipes are exactly 2.0" outer diameter, then yes - along with t-bolt clamps as someone already mentioned.
Please confirm your hardpipe outer diameter before you purchase. I thought my hardpipes were 2.0" also, but then I measured just before I ordered and the OD was 2.25" (RTM)
