smo0f said:update?
msfamilia said:See we are really trying to help a brother out here.......
Someone is more concern than filmer himself..... (headbang)
ZenProtege said:it takes a lot of the turbulance out of the airflow before it hits the sensor wires in the maf. I would leave it in there, I sure it makes the maf read much more accurately. IIRC, the mesh is glued in there anyways so getting it out would be pretty difficult. It's not like the silencer that DSM's have....
Is you MAF relocated as well?FlyinMSP said:I got mine out easily. The thottle response feels better without the mesh. Mine has been out for 2 years now. I did put it back to double-check a year ago, and I still found the car better without it.
wow, that's kind of what I was thinking being as though no one has posted up with issues. A new MAF is over $200 so I just wanted to be sure the relocation can withstand the test of time. I'm still waying the option of relocating or running the dual BOV/BPV set up. thanks for the infosmo0f said:several people have had it over 2 years and had reported no problems or downsides. it sounds like it's definitely worth it
boostisfun357 said:Is you MAF relocated as well?
boostisfun357 said:wow, that's kind of what I was thinking being as though no one has posted up with issues. A new MAF is over $200 so I just wanted to be sure the relocation can withstand the test of time. I'm still waying the option of relocating or running the dual BOV/BPV set up. thanks for the info
smo0f said:well although a bov/bpv setup might be cheaper (somehow, if that's the case), relocating the maf closer to the TB should be better because you are getting the reading of the air right before it enters the TB which yields better afrs and a faster throttle response due to the fact that there is little reaction time needed to dump fuel as per the amount of air entering. whereas with the stock setup, you are measuring air right at the intake, and the ecu reacts quickly to dump fuel but there's a bit of a delay until the air that was read reaches the combustion area to mix with the fuel that was released for that amount of air. i hope that made sense, it seems logical to me.
Matrix said:Also see post #31 in this thread. (thumb)
