I Need Help!!!
radman3120
92 B2200
Hello All,
I need some help seeing as I do not know much about Mazdas. We recently purchased a '92 B2200 truck which, although it needed some work, drove decently when we looked at it. Now, after a week of driving it the bearings are gone and its smoking like crazy.
What engines came in the B2200's? What will bolt directly up to the current 2.2L (I believe its a 2.2) motor mounts? Any other suggestions or advice as to what motor to go with or problems (harnesses, computers, etc) that I might come across? Thanks
The B2200 has the "F2" 2.2 liter engine. The only other direct swap in is the "FE" 2.0 engine from the B2000. Some cars had the F2 block, and bolt to the b2200 mounts, but used a different head, set up for transverse mounting, not an easy swap.
JT
