I Hate The P5 Transmission
I have a little problem in reverse let of on the clutch a little works for me. Any body ever had it jump out of third before? It is a shock.
if you don't bring it up I wouldn't even realize it but I have the same problem. Don't bother me though cuz first gear then reverse solves it everytime.
That sucks. Mine does that every once in a while.
Try shifting with a damn Tremec TKO tranny. I had one in my 65 stang, it grinded loud as hell every time I shifted to reverse.
Hellnightkid said:
KB bushing helped mine a little bit...i think.
I've got the KB bushing and TMM SS and it still happens once a while..=p but no big deal
Lord_Zath said:
Was wondering when someone would remember I have an automatic (first)
I'm not having clutch problems, either lol
Is yours of the magic or the tragic variety? :p
I just make sure to come to a complete stop before shifting to reverse. If not, it grinds even if the clutch is pushed in all the way, bah.
I always go to third, and then reverse. Sometimes if I let out the clutch then put it back in, the car will go into reverse but with a grind, so I always go to another gear first as a safety measure.
Mine does it occasionally in reverse, but I have more frequent problems shifting into 1st. Sucks when I'm sitting at a stop light and the shifter won't slot into 1st and I'm on level ground so the car won't roll if I let off the brake. Annoying as hell.
trying lining up the synchro's... go into 1st, then 2nd then in reverse, do that several times...it should be good after that
Tre, your sig looks a bit tall, you're allowed 300 pixels in height
