- 92 & 16 Meyatas
You should be at 10 PSI by now!
Time (sec) Load RPM Advance Throttle V AFR
0.000s 160.7mmHg 3353rpm 34.5deg 25.70% 14.02V 17.1afr
0.083s 90.9mmHg 3383rpm 31.0deg 43.85% 14.26V 17.2afr
0.167s 53.4mmHg 3284rpm 29.0deg 69.23% 14.33V 16.3afr
0.250s 33.2mmHg 3386rpm 28.5deg 95.65% 14.20V 14.6afr
0.333s 22.7mmHg 3527rpm 28.0deg 99.87% 14.22V 13.4afr
0.417s 6.9mmHg 3564rpm 27.5deg 99.87% 14.27V 12.9afr
0.500s 0.3psi 3603rpm 27.0deg 99.87% 14.27V 13.1afr
0.583s 0.6psi 3729rpm 26.5deg 99.87% 14.33V 13.1afr
0.667s 1.0psi 3817rpm 26.0deg 99.87% 14.26V 13.1afr
0.750s 1.5psi 3895rpm 25.5deg 99.87% 14.06V 13.2afr
0.833s 2.2psi 3983rpm 24.5deg 99.87% 14.10V 13.5afr
0.917s 2.7psi 4088rpm 23.5deg 99.87% 14.10V 13.5afr
1.000s 3.5psi 4188rpm 22.5deg 99.87% 14.14V 14.3afr
1.083s 4.3psi 4314rpm 21.5deg 99.87% 14.24V 14.4afr
1.167s 5.0psi 4442rpm 20.5deg 99.87% 14.41V 14.0afr
1.250s 5.5psi 4549rpm 20.0deg 99.87% 14.00V 13.5afr
1.333s 5.5psi 4661rpm 20.0deg 99.87% 14.10V 13.2afr
1.417s 5.3psi 4783rpm 20.0deg 99.87% 14.10V 12.9afr
1.500s 5.2psi 4899rpm 21.0deg 99.87% 14.29V 12.9afr
1.583s 5.1psi 5025rpm 21.5deg 99.87% 14.37V 12.8afr
1.667s 5.0psi 5135rpm 21.5deg 99.87% 14.39V 13.1afr
1.750s 4.9psi 5250rpm 22.0deg 99.87% 14.22V 13.2afr
1.833s 4.9psi 5375rpm 22.0deg 99.87% 13.94V 13.4afr
1.917s 4.9psi 5501rpm 22.5deg 99.87% 14.08V 13.2afr
2.000s 4.8psi 5596rpm 23.0deg 99.87% 14.06V 13.2afr
2.083s 4.8psi 5710rpm 23.5deg 99.87% 14.14V 13.1afr
2.167s 4.8psi 5836rpm 24.0deg 99.87% 12.55V 12.9afr
2.250s 4.7psi 5930rpm 24.5deg 99.87% 11.90V 12.8afr
2.333s 4.8psi 6034rpm 25.0deg 99.87% 11.82V 12.8afr
2.417s 4.7psi 6140rpm 25.5deg 99.87% 11.73V 12.6afr
2.500s 4.6psi 6240rpm 26.0deg 99.87% 11.71V 12.6afr
2.583s 4.6psi 6334rpm 26.0deg 85.76% 11.67V 12.6afr
2.667s 3.3psi 6560rpm 28.5deg 20.67% 11.63V 12.6afr
2.750s 132.9mmHg 6546rpm 37.0deg 0.00% 11.57V 11.0afr
2.833s 349.7mmHg 6306rpm 49.0deg 0.00% 11.59V 12.8afr
2.917s 496.7mmHg 6078rpm 52.0deg 3.44% 11.51V 12.2afr
3.000s 443.5mmHg 5984rpm 51.0deg 53.30% 11.55V 10.9afr
3.083s 96.9mmHg 5476rpm 32.5deg 99.87% 11.63V 13.4afr
3.167s 0.3psi 5025rpm 27.5deg 99.87% 11.63V 17.1afr
3.250s 2.1psi 4570rpm 24.5deg 99.87% 11.75V 16.5afr
3.333s 3.3psi 4874rpm 23.0deg 99.87% 11.69V 16.2afr
3.417s 4.1psi 4978rpm 22.5deg 99.87% 11.65V 15.1afr
3.500s 5.1psi 4850rpm 21.0deg 99.87% 11.57V 14.3afr
3.583s 5.1psi 5046rpm 21.5deg 99.87% 11.43V 13.4afr
3.667s 5.0psi 5051rpm 21.5deg 99.87% 11.55V 12.9afr
3.750s 5.0psi 5081rpm 21.5deg 99.87% 11.63V 13.1afr
3.833s 4.9psi 5185rpm 22.0deg 99.87% 11.57V 13.1afr
3.917s 4.9psi 5217rpm 22.0deg 99.87% 11.65V 13.2afr
4.000s 4.8psi 5264rpm 22.0deg 99.87% 11.41V 13.5afr
4.083s 4.8psi 5336rpm 22.5deg 99.87% 11.45V 13.4afr
4.167s 4.8psi 5370rpm 22.5deg 99.87% 11.35V 13.2afr
4.250s 4.8psi 5435rpm 22.5deg 99.87% 11.33V 13.1afr
4.333s 4.7psi 5470rpm 22.5deg 99.87% 11.39V 13.2afr
4.417s 4.8psi 5527rpm 23.0deg 99.87% 11.35V 12.9afr
4.500s 4.8psi 5585rpm 23.0deg 99.87% 11.43V 12.9afr
4.583s 4.7psi 5623rpm 23.0deg 99.87% 11.26V 12.8afr
4.667s 4.8psi 5672rpm 23.5deg 99.87% 11.27V 12.5afr
4.750s 4.7psi 5722rpm 23.5deg 99.87% 11.29V 12.6afr
4.833s 4.8psi 5772rpm 23.5deg 99.87% 11.27V 12.8afr
4.917s 4.7psi 5824rpm 24.0deg 92.47% 11.12V 12.5afr
5.000s 3.7psi 6160rpm 26.5deg 24.72% 11.22V 12.3afr
5.083s 111.2mmHg 6306rpm 35.0deg 0.00% 11.14V 11.0afr
5.167s 350.5mmHg 6084rpm 49.0deg 0.00% 11.12V 11.9afr
5.250s 496.7mmHg 5876rpm 52.0deg 0.00% 11.16V 11.6afr
5.333s 589.0mmHg 5683rpm 53.0deg 0.00% 11.26V 10.9afr
5.417s 622.0mmHg 5486rpm 49.5deg 1.54% 11.12V 10.6afr
5.500s 593.5mmHg 5355rpm 52.5deg 24.56% 11.29V 10.4afr
5.583s 276.2mmHg 4866rpm 46.5deg 49.25% 11.29V 10.4afr
5.667s 49.7mmHg 4302rpm 30.0deg 70.00% 11.24V 15.6afr
5.750s 0.2psi 4428rpm 28.0deg 77.86% 11.16V 16.6afr
5.833s 0.9psi 4402rpm 26.5deg 72.98% 11.31V 15.0afr
5.917s 1.8psi 4415rpm 25.0deg 48.72% 11.29V 14.7afr
6.000s 2.0psi 4455rpm 24.5deg 32.83% 11.26V 14.6afr
6.083s 0.3psi 4428rpm 27.5deg 14.71% 11.29V 14.4afr
6.167s 188.5mmHg 4369rpm 39.5deg 0.00% 11.20V 13.4afr
6.250s 373.0mmHg 4261rpm 49.5deg 0.00% 11.18V 11.6afr
6.333s 493.0mmHg 4455rpm 51.5deg 0.00% 11.20V 11.2afr
6.417s 587.5mmHg 4372rpm 52.5deg 0.00% 11.26V 12.2afr
6.500s 622.7mmHg 4327rpm 48.5deg 0.00% 11.31V 12.9afr
6.583s 638.5mmHg 4359rpm 44.5deg 0.00% 11.22V 12.9afr
6.667s 643.7mmHg 4305rpm 43.5deg 0.00% 11.16V 11.8afr
6.750s 646.7mmHg 4317rpm 42.5deg 0.00% 11.10V 11.3afr
6.833s 651.2mmHg 4289rpm 41.5deg 0.00% 10.86V 12.1afr
6.917s 651.2mmHg 4283rpm 42.0deg 0.00% 10.96V 12.6afr
7.000s 649.0mmHg 4249rpm 42.0deg 0.00% 11.04V 13.2afr
7.083s 649.0mmHg 4252rpm 42.0deg 0.00% 11.08V 13.2afr
7.167s 654.2mmHg 4218rpm 40.5deg 0.00% 11.10V 13.4afr
7.250s 648.2mmHg 4197rpm 41.5deg 0.00% 11.14V 13.4afr
7.333s 652.0mmHg 4161rpm 41.0deg 0.00% 10.92V 13.5afr
7.417s 649.0mmHg 4140rpm 41.5deg 0.00% 11.14V 14.1afr
7.500s 651.2mmHg 4100rpm 41.5deg 0.00% 11.06V 15.3afr
7.583s 647.5mmHg 4080rpm 41.5deg 0.00% 11.08V 15.9afr
7.667s 646.7mmHg 4052rpm 42.5deg 0.00% 10.96V 16.8afr
7.750s 649.0mmHg 4016rpm 41.5deg 0.00% 10.98V 17.1afr
7.833s 641.5mmHg 3996rpm 43.5deg 0.00% 11.18V 17.6afr
7.917s 642.2mmHg 3956rpm 43.0deg 0.00% 11.10V 18.4afr
8.000s 643.0mmHg 3943rpm 42.5deg 0.00% 11.04V 19.0afr
8.083s 639.2mmHg 3893rpm 44.0deg 0.00% 11.08V 19.6afr
8.167s 639.2mmHg 3882rpm 43.0deg 0.00% 11.06V 20.0afr
8.250s 641.5mmHg 3872rpm 43.0deg 0.00% 10.94V 20.3afr
8.333s 640.7mmHg 3827rpm 43.5deg 0.00% 10.88V 20.4afr
8.417s 637.7mmHg 3822rpm 44.5deg 0.00% 11.08V 20.4afr
8.500s 635.5mmHg 3799rpm 44.0deg 0.00% 11.06V 20.4afr
8.583s 637.0mmHg 3777rpm 45.0deg 0.00% 10.96V 20.6afr
8.667s 636.2mmHg 3765rpm 44.5deg 0.00% 11.10V 20.6afr
8.750s 637.7mmHg 3732rpm 44.5deg 0.00% 10.90V 20.7afr
8.833s 635.5mmHg 3729rpm 43.5deg 0.00% 11.00V 20.6afr
8.917s 633.2mmHg 3694rpm 45.0deg 0.00% 11.04V 20.6afr
9.000s 637.0mmHg 3708rpm 44.5deg 0.00% 10.98V 20.7afr
9.083s 632.5mmHg 3696rpm 45.0deg 0.00% 11.14V 20.7afr
9.167s 632.5mmHg 3706rpm 45.0deg 0.00% 11.12V 20.9afr
9.250s 635.5mmHg 3689rpm 45.0deg 0.00% 11.06V 21.0afr
9.333s 637.0mmHg 3662rpm 43.5deg 0.00% 11.06V 21.0afr
9.417s 634.0mmHg 3680rpm 44.5deg 0.00% 11.12V 21.0afr
9.500s 634.0mmHg 3666rpm 44.5deg 0.00% 10.98V 21.0afr
9.583s 635.5mmHg 3671rpm 44.5deg 0.00% 11.02V 21.0afr
9.667s 633.2mmHg 3664rpm 44.5deg 0.00% 11.16V 20.9afr
9.750s 632.5mmHg 3657rpm 44.5deg 0.00% 11.12V 21.0afr
9.833s 634.7mmHg 3659rpm 44.5deg 0.00% 11.02V 20.9afr
9.917s 637.0mmHg 3643rpm 44.0deg 0.00% 11.06V 21.0afr
10.000s 632.5mmHg 3650rpm 44.0deg 0.00% 11.10V 21.0afr
10.083s 631.7mmHg 3634rpm 45.0deg 0.00% 11.14V 21.0afr
10.167s 633.2mmHg 3641rpm 44.5deg 0.00% 11.12V 21.0afr
10.250s 634.7mmHg 3632rpm 44.0deg 0.00% 11.02V 20.9afr
10.333s 635.5mmHg 3641rpm 44.5deg 0.00% 10.90V 21.0afr
10.417s 636.2mmHg 3632rpm 44.0deg 0.00% 11.00V 21.0afr
10.500s 631.7mmHg 3637rpm 44.0deg 0.00% 11.10V 20.9afr
10.583s 634.0mmHg 3628rpm 44.0deg 0.00% 11.14V 21.0afr
10.667s 634.0mmHg 3637rpm 44.5deg 0.00% 11.14V 21.0afr
10.750s 631.7mmHg 3614rpm 45.0deg 0.00% 11.08V 21.0afr
10.833s 634.7mmHg 3634rpm 44.5deg 0.00% 10.98V 21.0afr
10.917s 637.0mmHg 3612rpm 44.0deg 0.00% 10.84V 20.9afr
11.000s 622.7mmHg 3032rpm 41.0deg 0.00% 11.04V 20.6afr
11.083s 626.5mmHg 3023rpm 39.5deg 0.00% 11.00V 20.7afr
11.167s 622.0mmHg 3017rpm 40.5deg 0.00% 11.06V 20.6afr
11.250s 628.7mmHg 2989rpm 38.5deg 0.00% 10.90V 20.6afr
11.333s 622.0mmHg 2987rpm 40.0deg 0.00% 11.10V 20.7afr
11.417s 624.2mmHg 2968rpm 39.5deg 0.00% 11.00V 20.6afr
11.500s 621.2mmHg 2944rpm 40.0deg 1.95% 10.98V 20.6afr
11.583s 607.0mmHg 2971rpm 42.5deg 3.95% 11.08V 20.9afr
11.667s 577.0mmHg 2965rpm 42.5deg 6.50% 11.08V 20.6afr
11.750s 527.5mmHg 2923rpm 41.5deg 8.13% 11.04V 20.4afr
11.833s 466.0mmHg 2915rpm 40.5deg 12.32% 10.88V 20.1afr
11.917s 338.5mmHg 2934rpm 38.5deg 19.46% 10.90V 18.7afr
12.000s 177.2mmHg 3026rpm 34.0deg 25.66% 11.10V 17.6afr
12.083s 97.7mmHg 2935rpm 30.0deg 28.65% 10.98V 16.9afr
12.167s 75.2mmHg 2971rpm 29.5deg 32.83% 10.86V 16.2afr
12.250s 45.2mmHg 2984rpm 28.5deg 41.59% 11.04V 14.8afr
12.333s 27.2mmHg 2997rpm 28.0deg 43.87% 11.08V 14.6afr
12.417s 18.9mmHg 3012rpm 27.5deg 44.81% 10.90V 14.1afr
12.500s 1.7mmHg 3028rpm 27.0deg 45.07% 11.16V 14.3afr
12.583s 0.2psi 3054rpm 27.0deg 45.09% 10.96V 14.3afr
12.667s 0.6psi 3070rpm 26.0deg 44.69% 11.06V 14.4afr
12.750s 0.9psi 3093rpm 25.5deg 42.31% 11.06V 14.4afr
12.833s 1.0psi 3120rpm 25.5deg 36.54% 10.82V 14.1afr
12.917s 1.1psi 3148rpm 25.5deg 29.85% 10.98V 14.0afr
13.000s 0.8psi 3162rpm 26.0deg 22.03% 11.12V 14.0afr
13.083s 0.2psi 3177rpm 27.0deg 19.60% 11.14V 13.8afr
13.167s 22.7mmHg 3201rpm 27.5deg 17.53% 11.08V 13.8afr
13.250s 42.9mmHg 3219rpm 28.5deg 16.54% 11.08V 13.7afr
13.333s 67.7mmHg 3237rpm 29.5deg 15.56% 11.06V 13.7afr
13.417s 81.2mmHg 3255rpm 30.5deg 14.43% 11.10V 13.7afr
13.500s 117.9mmHg 3267rpm 32.0deg 12.81% 11.04V 13.8afr
13.583s 159.2mmHg 3288rpm 34.0deg 11.92% 10.94V 13.7afr
13.667s 193.0mmHg 3302rpm 36.0deg 11.27% 10.96V 13.7afr
13.750s 218.5mmHg 3306rpm 37.5deg 9.34% 10.98V 13.5afr
13.833s 285.2mmHg 3308rpm 42.5deg 6.49% 11.06V 13.8afr
13.917s 367.7mmHg 3304rpm 45.5deg 4.36% 10.90V 13.7afr
14.000s 437.5mmHg 3308rpm 46.5deg 2.41% 10.98V 13.2afr
48.583s 515.5mmHg 997rpm 8.5deg 0.00% 11.08V 18.1afr
48.667s 514.0mmHg 994rpm 8.5deg 0.00% 11.06V 17.6afr
48.750s 507.2mmHg 970rpm 8.5deg 0.00% 11.00V 17.9afr
48.833s 500.5mmHg 934rpm 8.5deg 0.00% 11.14V 17.5afr
48.917s 496.0mmHg 933rpm 8.5deg 0.00% 11.08V 17.6afr
49.000s 490.7mmHg 907rpm 8.5deg 0.00% 10.96V 17.3afr
49.083s 485.5mmHg 894rpm 8.5deg 0.00% 11.06V 16.8afr
49.167s 479.5mmHg 901rpm 8.5deg 0.00% 11.00V 16.9afr
49.250s 446.5mmHg 918rpm 8.5deg 12.28% 11.08V 16.2afr
49.333s 199.7mmHg 944rpm 9.0deg 33.60% 10.94V 16.5afr
49.417s 29.4mmHg 922rpm 9.5deg 44.26% 11.08V 16.5afr
49.500s 30.9mmHg 1284rpm 12.5deg 52.83% 10.96V 15.9afr
49.583s 39.2mmHg 1773rpm 18.0deg 61.08% 11.08V 16.0afr
49.667s 48.2mmHg 2443rpm 23.5deg 77.37% 11.02V 14.1afr
49.750s 51.9mmHg 2983rpm 28.5deg 89.03% 10.96V 12.8afr
49.833s 58.7mmHg 3599rpm 29.5deg 96.61% 10.67V 12.1afr
49.917s 69.9mmHg 4200rpm 30.5deg 99.87% 10.59V 12.1afr
50.000s 79.7mmHg 4779rpm 30.5deg 99.87% 10.69V 11.6afr
50.083s 72.9mmHg 5390rpm 31.0deg 80.98% 10.67V 11.6afr
50.167s 72.2mmHg 5930rpm 32.0deg 23.06% 10.47V 11.6afr
50.250s 281.5mmHg 6058rpm 46.0deg 0.00% 10.71V 10.9afr
50.333s 434.5mmHg 5858rpm 51.0deg 0.00% 11.78V 11.9afr
50.417s 552.2mmHg 5655rpm 52.5deg 0.00% 12.37V 12.9afr
50.500s 609.2mmHg 5445rpm 52.5deg 0.00% 12.75V 12.1afr
50.583s 626.5mmHg 5259rpm 47.5deg 0.00% 12.88V 11.5afr
50.667s 635.5mmHg 5103rpm 45.0deg 0.00% 12.94V 11.3afr
50.750s 644.5mmHg 4932rpm 43.0deg 0.00% 13.04V 11.8afr
50.833s 648.2mmHg 4759rpm 42.0deg 0.00% 13.22V 12.2afr
50.917s 648.2mmHg 4584rpm 42.0deg 0.00% 13.10V 12.5afr
51.000s 645.2mmHg 4415rpm 43.0deg 0.00% 13.24V 12.5afr
51.083s 643.7mmHg 4242rpm 43.5deg 0.00% 13.16V 13.1afr
51.167s 640.7mmHg 4069rpm 44.0deg 0.00% 13.16V 14.3afr
51.250s 634.0mmHg 3898rpm 45.5deg 0.00% 13.27V 15.7afr
51.333s 626.5mmHg 3727rpm 47.5deg 0.00% 13.31V 16.9afr
51.417s 619.7mmHg 3566rpm 47.0deg 0.00% 13.26V 17.6afr
51.500s 614.5mmHg 3386rpm 46.5deg 0.00% 13.31V 18.4afr
51.583s 607.7mmHg 3221rpm 46.5deg 0.00% 13.08V 19.0afr
51.667s 603.2mmHg 3069rpm 44.5deg 0.32% 13.41V 19.4afr
51.750s 576.2mmHg 2903rpm 41.5deg 9.61% 13.33V 19.7afr
51.833s 445.0mmHg 2812rpm 38.5deg 13.58% 13.41V 20.0afr
51.917s 298.7mmHg 2872rpm 36.5deg 11.21% 13.43V 20.1afr
52.000s 347.5mmHg 3069rpm 41.5deg 2.90% 13.61V 19.6afr
52.083s 442.0mmHg 3083rpm 44.0deg 2.76% 13.37V 18.5afr
52.167s 491.5mmHg 2947rpm 41.5deg 2.76% 13.51V 17.2afr
52.250s 519.2mmHg 2718rpm 37.5deg 2.76% 13.47V 15.9afr
52.333s 532.7mmHg 2470rpm 33.5deg 2.76% 13.59V 14.8afr
52.417s 528.2mmHg 2498rpm 34.5deg 6.02% 13.63V 14.7afr
52.500s 469.0mmHg 2538rpm 34.0deg 9.83% 13.75V 15.4afr
52.583s 367.0mmHg 2544rpm 32.5deg 11.67% 13.73V 15.9afr
52.667s 272.5mmHg 2576rpm 31.0deg 15.56% 13.75V 16.6afr
52.750s 178.7mmHg 2509rpm 28.0deg 16.52% 13.73V 17.1afr
52.833s 129.9mmHg 2573rpm 27.5deg 19.48% 13.78V 17.1afr
52.917s 96.9mmHg 2538rpm 26.0deg 19.60% 13.71V 16.8afr
53.000s 90.2mmHg 2573rpm 26.5deg 19.39% 13.67V 16.2afr
53.083s 99.2mmHg 2562rpm 26.5deg 13.01% 13.78V 15.7afr
53.167s 147.2mmHg 2573rpm 28.0deg 12.32% 13.98V 15.0afr
53.250s 169.7mmHg 2582rpm 28.5deg 11.85% 13.92V 14.4afr
53.333s 175.7mmHg 2585rpm 28.5deg 12.34% 13.86V 14.3afr
53.417s 166.0mmHg 2603rpm 28.5deg 13.84% 13.84V 14.3afr
53.500s 131.4mmHg 2612rpm 28.0deg 15.40% 13.96V 14.4afr
53.583s 107.4mmHg 2618rpm 27.0deg 15.89% 14.00V 14.6afr
53.667s 96.9mmHg 2633rpm 27.0deg 15.89% 13.84V 15.0afr
53.750s 90.2mmHg 2644rpm 27.0deg 14.75% 14.12V 15.0afr
53.833s 131.4mmHg 2646rpm 28.5deg 10.17% 13.90V 14.7afr
53.917s 219.2mmHg 2646rpm 30.5deg 4.13% 13.98V 14.6afr
54.000s 335.5mmHg 2641rpm 34.0deg 0.02% 14.20V 14.0afr
54.083s 422.5mmHg 2653rpm 35.5deg 0.00% 14.16V 13.1afr
54.167s 484.7mmHg 2662rpm 36.5deg 0.04% 14.10V 12.2afr
54.250s 530.5mmHg 2648rpm 36.5deg 0.00% 13.59V 11.5afr
54.333s 557.5mmHg 2659rpm 37.0deg 0.00% 13.96V 11.2afr
54.417s 571.0mmHg 2671rpm 37.5deg 0.06% 13.96V 11.2afr
54.500s 580.0mmHg 2657rpm 37.5deg 0.00% 14.00V 11.5afr
54.583s 584.5mmHg 2665rpm 37.5deg 0.00% 13.88V 12.2afr
54.667s 585.2mmHg 2685rpm 38.0deg 0.00% 13.77V 13.1afr
54.750s 586.7mmHg 2654rpm 37.5deg 0.00% 14.14V 13.5afr
54.833s 588.2mmHg 2700rpm 38.0deg 0.00% 14.20V 14.1afr
54.917s 588.2mmHg 2660rpm 37.5deg 0.00% 13.67V 15.3afr
55.000s 589.0mmHg 2693rpm 38.0deg 0.00% 14.02V 16.8afr
55.083s 589.0mmHg 2680rpm 37.5deg 0.00% 13.94V 17.3afr
55.167s 588.2mmHg 2686rpm 38.0deg 0.00% 13.96V 17.8afr
55.250s 588.2mmHg 2675rpm 37.5deg 0.00% 13.88V 18.4afr
55.333s 586.7mmHg 2690rpm 38.0deg 0.00% 13.61V 18.8afr
55.417s 587.5mmHg 2662rpm 37.5deg 0.00% 13.78V 19.0afr
55.500s 589.0mmHg 2692rpm 38.0deg 0.00% 13.86V 19.3afr
55.583s 586.0mmHg 2671rpm 37.5deg 0.00% 14.12V 19.7afr
55.667s 586.7mmHg 2687rpm 38.0deg 0.00% 14.14V 20.1afr
55.750s 587.5mmHg 2671rpm 37.5deg 0.00% 13.86V 20.6afr
55.833s 588.2mmHg 2684rpm 38.0deg 0.00% 14.31V 21.0afr
55.917s 589.0mmHg 2696rpm 38.0deg 0.00% 13.96V 21.3afr
56.000s 589.0mmHg 2685rpm 38.0deg 0.00% 14.14V 21.5afr
56.083s 587.5mmHg 2674rpm 37.5deg 0.00% 13.92V 21.6afr
56.167s 589.0mmHg 2645rpm 37.0deg 0.00% 14.06V 21.8afr
56.250s 587.5mmHg 2636rpm 37.0deg 0.00% 14.18V 21.8afr
56.333s 587.5mmHg 2632rpm 37.0deg 0.00% 14.20V 21.8afr
56.417s 587.5mmHg 2647rpm 37.0deg 0.00% 13.82V 21.9afr
56.500s 588.2mmHg 2627rpm 37.0deg 0.00% 14.00V 21.9afr
56.583s 589.0mmHg 2627rpm 37.0deg 0.00% 14.00V 21.9afr
56.667s 588.2mmHg 2623rpm 37.0deg 0.00% 14.02V 21.9afr
56.750s 586.0mmHg 2618rpm 36.5deg 0.00% 13.98V 21.9afr
56.833s 587.5mmHg 2620rpm 36.5deg 0.00% 13.96V 21.9afr
56.917s 588.2mmHg 2611rpm 36.5deg 0.00% 14.14V 21.9afr
57.000s 586.0mmHg 2600rpm 36.5deg 0.00% 14.08V 21.9afr
57.083s 585.2mmHg 2590rpm 36.5deg 0.00% 14.16V 21.9afr
57.167s 586.7mmHg 2611rpm 36.5deg 0.00% 13.90V 21.9afr
57.250s 584.5mmHg 2586rpm 36.5deg 0.02% 14.10V 21.8afr
57.333s 585.2mmHg 2584rpm 36.0deg 0.00% 14.02V 21.9afr
57.417s 585.2mmHg 2553rpm 35.5deg 0.00% 14.08V 21.9afr
57.500s 586.7mmHg 2549rpm 35.5deg 0.00% 14.18V 21.9afr
57.583s 584.5mmHg 2550rpm 35.5deg 0.00% 13.96V 21.9afr
57.667s 584.5mmHg 2544rpm 35.5deg 0.00% 14.00V 21.9afr
57.750s 585.2mmHg 2524rpm 35.0deg 0.00% 14.06V 21.9afr
57.833s 584.5mmHg 2527rpm 35.5deg 0.00% 14.02V 21.9afr
57.917s 583.0mmHg 2511rpm 35.0deg 0.00% 14.10V 21.9afr
58.000s 583.7mmHg 2508rpm 35.0deg 0.00% 14.16V 21.9afr
58.083s 583.7mmHg 2492rpm 34.5deg 0.00% 14.16V 21.9afr
58.167s 583.0mmHg 2494rpm 34.5deg 0.00% 14.06V 21.9afr
58.250s 583.0mmHg 2479rpm 34.5deg 0.00% 14.08V 21.9afr
58.333s 581.5mmHg 2471rpm 34.5deg 0.00% 13.98V 21.9afr
58.417s 580.0mmHg 2465rpm 34.0deg 0.00% 13.92V 21.9afr
58.500s 576.2mmHg 2434rpm 33.5deg 2.03% 14.06V 21.9afr
58.583s 556.7mmHg 2511rpm 34.5deg 4.72% 14.14V 21.8afr
58.667s 520.7mmHg 2476rpm 34.0deg 5.45% 14.18V 21.9afr
58.750s 488.5mmHg 2424rpm 32.5deg 6.36% 14.08V 21.6afr
58.833s 456.2mmHg 2449rpm 32.0deg 7.01% 14.12V 20.6afr
58.917s 427.7mmHg 2414rpm 31.5deg 7.11% 13.94V 19.4afr
59.000s 410.5mmHg 2426rpm 31.5deg 6.97% 14.06V 18.5afr
