2 day track event over. (NJMP Lightning, was there with NASA)
Car held up fantastically. Zero overheating issues. The only indication I really had of temps (other than the worthless stock temp gauge) was A) A rev limit cut in the Hydra to ~3,900rpm if I hit 235 water temps, which never happened, and B) how I only had 1 fan running when I came off track, and the 2nd fan is set to 203f. Granted, there is some cooldown driving before I could check that, about a minute's worth, but i think it looks like the temps stayed completely under control. Ambient was also ~60f. Probably a different story later this year.
I did pick up some knock at 6,500rpm in 5th at WOT coming onto the front straight and immediately felt the timing pull, saw the CEL pop up, and I lifted. I short shifted 5th a bit more, at ~5,500 for the rest of the day. It appears that I was seeing some boost creep? As I glanced at the boost gauge the next few laps at that point, and the needle was hovering around 10psi, rather than the 8 of normal. The Hydra should be able to handle that without an issue, so not really sure yet how to approach figuring out exactly what happened. Gas quality is certainly possible, as I had filled up outside of the track in town since the track ran out of 93. The quality might have been lower.
I also popped the hood after one session and found that there was oil seeping from around the oil cap, and my dip stick had been lifted out of the dipstick tube. I assume it means crankcase being pressurized, and will have to look into solutions for that.
Best part of the weekend? After 6 sessions, my instructor felt I was ready to move to DE2, and said I could solo for the last 2 sessions of DE1. I opted to find another instructor for the 3rd session yesterday (who happened to drive a Ford 302 swapped NA Miata), who completely agreed with the assessment.
I didn't do the 4th session, exhaustion setting in and a 2.5 hr drive home pending.
