HPF pump
Dr. D
looking for some tips on the install of the HPF pump... one question right off the bat does the pump cover really have to be unbolted? the directions say to remove the pump cover and then tighten the pump cover right away
? a bit confused at that part. any helpful hints are greatly appreciated!
no this is the High Pressure Fuel Pump on the drivers side of the engine. the secondary pump if you will.
does this have anything to do with the Walbro 255 ??? im thinking about installing into my car
ATEBALLER is the ONLY person that actually has a Walbro 255 up and running. It took 3 very creative, knowledgable guys to jerry-rig that. Based on your track record, you will not succeed. you might want to not touch any more mods without adult and professional supervision.
