Where is your 2017 CX-5 CD player located?Mute is simply just that - being Mute. Sadly if playing a CD or USB the mute doesn't stop the device from continuing to play, if you try it with a CD and listen carefully you will hear it spinning in the background. So if you press mute whilst in conversation, then press again an hour later you won't continue where you left off, you're then a long way ahead in whatever you were listening to. I make a point of switching to DAB radio then mute.
Yep UK or most EU countries has CD player in 2nd-gen CX-5. Japan has DVD player but Australia has none like in the US. (notcool)
Maybe hook up a portable CD player instead (uhm)I wonder if the CD player can be retrofitted to the 2017 US model? Obviously, the player itself and the front of the dash would need to be replaced. No idea about the internal wiring - perhaps just plug-n-play? Yeah, I'm an older dude which a large CD collection![]()
Rip that stuff and put hundreds on single memory stick.
I've done some unfortunately the sound quality is not as good as original CD's!Rip that stuff and put hundreds on single memory stick.
