How to lube front bushings?
faral
My front passenger wheel squeaks every time I hit a bump. I recently had the strut and wheel bearing replaced, so it's not those things squeaking (if they are even capable of squeaking). A friend suggested lubing the bushing...
So...does anyone have any experience with this? Where is it and how do I get to it? What kind of lube do I use? Some kind of super thick silicone grease?
I should mention that the squeaking was there and sounds identical before and after all the replacements...
the front suspension bushings are rubber and don't typically require maintenance. i'm suspecting the sound is coming from somewhere else.
