HOW-TO: Install In-Tank Fuel Pump
The fuel pump you need is a 94-97 Miata Walbro 255 LPH HP. P/N GSS342
One of these is the stock Miata pump, and the other is the stock Protege pump.
Step One: Remove Gas Cap. Flip drivers side rear seat forward.
Step Two: Lift flap and remove 4 cover screws.
Step Three: Unplug the two plugs.
Step Four: You will need to remove this plug that I am holding from its holder that I am pointing to.
Step Five: Now remove the Fuel Lines. This is tricky. Just use a small flat tip screw driver to lift each side of the green clip over the lip on the line.
