How-To install a turbo timer * Write up *
Thanks a lot for the write up I found it very useful. Here are a few pictures I took that I thought some people might appreciate or find useful. (Hopefully they upload properly I am new to using forums)
I think they uploaded just wondering if anyone can tell me how to make the pictures appear within your text like in the write up
Has anybody find a way to get the apexi tt to work as per alarm function with door locked for the 2006-2007 mazdaspeed 6 yet ,i spend all day trying to install mine got it to work as designed but alarm does not arm when pressed from remote or door ,only way i got it to work was to take the 15amp fuse out for the meter ig in the fuse panel ,note i do not have a wiring diagram to work with so i was just using my electrical skills there ,can some one post the wiring diagrams for the cars alarm system thanks will help alot to solve this issue for the speed 6 drivers with a apexi tt ,cool.
Has anyone done this install on a 2nd gen MS3 with push button start? I just tore into my dash and couldn't find any of the 16 gauge ignition/ACC/constant 12V wires. My guess is that the wires from the push button switch goes to a relay somewhere because they are about 20/22 gauge. Any suggestions?
Me to I mazdaspeed 3 2008! but I still have a little problem with my turbo timer. My turbo timer is still 0.00 if my fan is closed. My turbo timer works if my fan is open.
