How To: Haltech Max Boost Pressure Adjustment with Haltec Boost Controller
LinuxRacr
Contributor
2001 Mazda MP3
You have to have the Haltech Boost Control Solenoid to do this:
Hit Control+O
This will bring up the PWM Output Options under the Options menu.
Chose the PWM Output that is connected to your Haltech Boost Solenoid. The Drop-down window will say "Turbo Wastegate". Click the Properties radio button. The Turbo Wastegate window will pop up:
You will then adjust the Max Boost Pressure (kPa) to the max you want the boost to be at (in killopascals NOT psi) when your boost knob is turned all the way up. If you don't have a PSI to kPa conversion utility handy, go ahead and download this fee utility from ESB. It is the best!:
http://www.esbconsult.com/esbcalc/esbunitconv.html
Just use the Pressure tab to convert from PSI to Killopascals.
The Haltech now has imperial units for those of you wanting to display boost pressure in PSI, and Temperature in Farenhieht. Go to the setup menu, and then choose Program Setup. Choose either imperial, or metric:
What is your WG map set at? I had to move all my bars to 100% or this wouldn't work, but I get some strange oscilation in boost. Dyno tuning tomorrow, so I will post findings.
