problem broken door switch snapped in half when it caught on my pant leg.
new switch without boot.
how to install new switch.
first pop plastic cover off on driver side
pull driver back seat cover
make sure all your tabs are there
next peel center piece out, this is a little tough but she will come out.
you will see a bunch of wires, go ahead and look through the small opening and tug at the wires you will see which one you will have to pull out.
turns out the female connector was loose also so I had to replace that as well.
this is how it connects
now unplug it, fish the wire through the opening and pug together again.
now put the phillips screw back in and torque everything back down. If you did this right you will be able to see your door signal light come off and on when the door switch is pressed.
now put all your covers back on in reverse order and your good to go.
The door switch is around 4-5 bucks at pick and pull.
