Bala de Plata said:Did you do an intake at the same time? - MAF may be flipped ...
cplagge said:the CEL light will not turn on when i put the key onto the on position. Something is very strange
cplagge said:all fuses intact. could it be that icould have a blown ecu?
if one of my o2 sensor wires is messed up, could that cause this problem
Yes that will throw a cel the first one is the most needed one also. Wrap the wires with some tape if you are getting metal to metal contact.cplagge said:ok so i re-attached the o2 sensor, and i noticed it is touching the metal from the clutch slave? its causing a short. Will i throw a cel if the first o2 sensor is not in?
mazdaspeed777 said:Subbin, Installing OBX header next weekend
