how much boost for lc.
koston33
I have my lc set to 2900, and I'm only building around 3lbs of boost when stationary, is that fine, I thought it would be more?
turn yourtraction control off with your current settings for LC and see if you dont roast your tires.
its fine at 2900. actaully should be lower.
Without an antilag system you wont build that much boost at a standstill, there isn't enough load on the engine to build much more boost than what you are seeing. 3lbs of boost is rather good for just sitting at 2,900 rpm and should be more than enought to get you off the line.
I agree that 2900 might be too much. I've got mine set to 2700 with upgraded motor mounts, suspension upgrades, and sticky R-comps and 2700 is perfect for me.
The Launch Control Speed Limit is the speed at which launch control is turned off. So you want to set it somewhat low so that when you get over say 15mph, LC shuts down and you are able to rev up to redline for the rest of your drag run.
