Mine seems to be consistently 3 mph under according to my phone gps speedo app.
Why do you believe the GPS and not the speedo?
interesting question. I always assumed that distance over time measurement with a GPS would be more accurate than a speedometer that has to deal with a multitude of tyre issues; wear, temperature, incorrect inflation, etc. A bit of googling has confirmed that GPS is more accurate.
Personally, i've just changed wheels and tyres and wanted to know. It does appear my speedo is accurate, Mazda have just added 3 to whatever speed I'm doing.
GPS will be more accurate.
Manufacturers typically set speedos to read a touch conservatively - usually 2-3% - they dont want us to get speeding tickets and then blame the speedo for reading under when actual speed was over the limit.
In the U.S., manufacturers voluntarily follow the standard set by the Society of Automotive Engineers, J1226. Manufacturers are afforded the latitude to aim for within plus-or-minus two percent of absolute accuracy or to introduce bias to read high on a sliding scale of from minus-one to plus-three percent at low speeds to zero to plus-four percent above 55 mph. And those percentages are not of actual speed but rather a percentage of the total speed range indicated on the dial. So the four-percent allowable range on an 85-mph speedometer is 3.4 mph, and the acceptable range on a 150-mph speedometer is 6.0 mph.
*Might explain why some vehicles that can barely break 100 have 180mph speedos, ROFL!
GPS *could* be more accurate. However, there are many variables that go into the accuracy of a GPS - how many satellites are visible, signal strength, signal reflection problems, how the chip does its computation, the software you're using may be rounding up... if you're in a city it's going to be less accurate than the countryside. An antenna outside the car may be more accurate than your phone inside the car.
The actual answer probably is somewhere in the middle between what the speedo reports (it has its own variables), and what the phone says.
