Hot mofo!
yashooa
Full Metal Mazda
MSP, The BLACKNESS!
I had heard from Joey Joo Ja that taking the weather stripping off the back of the ehgine compartment would reduce the under hood temperature. I didnt think too much of it until I was stopping and adjusting my MBC in the near 100 degree weather and when I touched the hood it was very hot, then I went to grab the prop bar and it was so damn hot I almost had the impression branded into my palm! This car gets very hot under the hood. So I spent the 60 seconds or so it takes to remove the snap on weather striping and viola a dramatic drop in the under hood temps. I am amazed at the difference it made. I can grab the prop bar now after a hard run and not have my skin peel off and stick to it. :D
It looks to very easily reinstalled if needed.
Not one bit of hesitation of course I have never had any but the heat has yet to cause any trouble for me other than the under hood temps being lethal to human skin.
show a picture of what your talkign about or tell mroe about what exactly it is. I'm trying to picture what your talking about..
Pickies for JU.
47b3d803b3127cce89877c28de470000001610
47b3d803b3127cce898772345f6c0000001610
47b3d803b3127cce898770cb5f920000001610
Same result here. I haven't noticed a change in the hesitation (yes, i have it bad) but the underhood temps have changed dramatically. Just put your hand over the opening at the back of the hood after a hard run and you can feel the heat venting big time.
Peace...(hippy)
Lot's of us in the DFW area it seems. I have to try to make it to one of the Cafe RPM meets, but time is precious these days...
Peace...(hippy)
HMMM
newf said:
so, the disadvantage would be......water getting in there? Which I can't see happening all that much
It dosen't see to be much of a problem. Maybe some of you Canuckers might need it for the snow.
This was discussed on another thread. Take a close look at the plastic drain piece just under the windshield. As this continues under the hood, it takes a sharp turn upwards leaving a small gap for air to escape in the absence of the weather strip. There is very little opportunity for water to get in. The tiny amount that might...who cares? IMHO, this is a no-risk free mod that can be undone in 5 minutes if you don't like it for any reason.
Peace...(hippy)
I'm confused on where the rock was in the engine bay? Why else point it out if it wasn't important; right?
:confused:
Newf:
The disadvantage is that all that hot underhood air is now sucked into the interior of the car when you have the vent pulling outside air in. That grille under the wipers feeds your ventilation system.
I don't think it's that bad since I took mine off. It rarely gets hot in Portland, so I don't use the air conditioner all that much.
sounds like a good quick fix. just replace back during the winter if water is a problem, since heat wont be much of a problem when that happens.
nice job.
Ammo
slug420 said:
i dont get it.
where does the rock go???
You take that to your dealer and when they say something brilliant like, "Ah well stalling is just a characteristic of the car."
You bash them in the head with it and tell them that being injured by a rock is just a "Characteristic" of their skull. :D
Disclaimer: My car doesn't stall it only purrs like large Black
Keet-un.
Re: Ammo
You bash them it the head with it and tell them that being injured by a rock is just a "Characteristic" of their skull. :D
Keet-un.
(rofl)
This literally made me laugh out loud in my office. Note to self: Work more, read less.
Peace...(hippy)
