Hood Rattle
cmm47172
2013 Mazda 2 Touring
I have a 2013 Mazda 2 Touring. I noticed when the hood is closed, I can lift it up and down about 1/4". Is there a way to adjust it to make it lock down tight? Thanks ahead of time to anyone who responds.
Assuming the hood is latched completely, and when you apply upward pressure the hood height is about right, all you need to do is adjust the two rubber snubbers:
If the hood latch needs adjusted, there should be a bit of play if you loosen the two bolts on the plastic radiator support to move it around for adjustment.
