Back seat rattle issue
We have had people in the back seat of our 2024 CX5 for the first time. We have noticed a rattle on one of the seats, when on a rough road and also when you push and pull the upper part of the seat. It is coming from the back cushion latch where on the car frame is a square frame that looks like for a door, Is there a way to tighten this just like you sometimes have to do on a car. The square comes through a slot in the panelling. Would such an adjustment be covered under the warranty? Thanks.
We have had people in the back seat of our 2024 CX5 for the first time. We have noticed a rattle on one of the seats, when on a rough road and also when you push and pull the upper part of the seat. It is coming from the back cushion latch where on the car frame is a square frame that looks like for a door, Is there a way to tighten this just like you sometimes have to do on a car. The square comes through a slot in the panelling. Would such an adjustment be covered under the warranty? Thanks. solitaire bliss
I had a similar issue on my 2023 CX-5. The rattling sound turned out to be from the seat latch area as well. I used some felt tape around the contact points where the seat meets the frame, and that reduced the noise significantly. You might want to try that as a quick fix. But I agree—if it's a design flaw or something loose from the factory, it should definitely be checked under warranty. Keep us posted if you get a dealership response!
