I believe so. Define feather.YP5 Toronto said:do you "feather" the gas peddle at all during the start?
Yup. Every time I do that it runs like s*** and then dies.YP5 Toronto said:sorta when its about to "catch" ...when its just about to ignite and hold... you add a bit of peddle...
Pretzellogic said:Pretz couple of Qs: Do you end up getting a starter/charger? What type of battery are you running? And did you install the new plugs?
Did install the new plugs. Still running stock battery. Have not bought a starter/charger yet.
Did the battery die? or do you think the plugs are wet?
The battery did not die. It will crank and sputter, but will not run.
LinuxRacr said:Dude, the stock battery is WEAK for cold temperatures. I had this problem. It possibly could be a power issue? When you crank, does it turn over fast like it is fixing to start, or is it a weak turnover?
It's pretty weak. Any suggestions for a good battery? Should I drop some cash on a red-top?LinuxRacr said:Dude, the stock battery is WEAK for cold temperatures. I had this problem. It possibly could be a power issue? When you crank, does it turn over fast like it is fixing to start, or is it a weak turnover?
Pretzellogic said:It's pretty weak. Any suggestions for a good battery? Should I drop some cash on a red-top?
So the optimas aren't worth it, eh?Captain KRM P5 said:my red top was horrible, frankly. i'd go with a yellow top or something heavy duty from Sears. honestly you can't beat Die Hard
What I thought as well.LinuxRacr said:Really? I thought Optimas were supposed to be the s***?
