Probably so. Not a big fan of the CC either. Kinda sucks, and definitely sucks for highway miles with hilly terrain. It can't Mimic pulling the hills like I can manually, it's way late to engage and revs way harder than it needs too, hence killing MPG.
This was my assumption - I was wrong. Although manually you can still beat the CC, it is pretty good. It downshifts when you want to slow down. Thus being more efficient. And like rest of the traits it is good - if you set at 60. It will be +/- 2 mph at max.
This is interesting. I assume you are referring to the 2017 model CX-5?
Can you and others chime in a bit more on this issue? Do you find the CC to be worse than other similar vehicles?
CC is good. Its true to Mazda driving traits. In a Toyota the CC will let you go +/- 6 mph or more before it decides to do something. In Mazda its much tighter.
