HD Lip Help
speed6r
2006 Black Cherry MS6
Can anyone tell me what the name of the product is, that we use for the HD lip? every time I go to HD for the stuff, I ask a employee for help and they look at me like im crazy! Also what do you use to adhear the lip to the stock front bumper
Thanks in advance
-Murder-
its garage door bottom deal... 2 and 1/4 wide 9' long! its a orange and white plastic wrapper! hold it on with 3m double sided tape or similar product, you can find the tape at hd or any auto store; be sure to get more then one roll. Also use half to one inch self tapping screws.
Refer here if needed!
http://www.mzspd6.com/forum/showthread.php?t=123722778
Good luck!
Use 3m Indoor/outdoor. Its the best. With the molding and tape at Home depot, it was like $13.
Just be precise when molding it, cause mine shows a little bit of the tape.
I didn't use screws on mine, and I've had mine on for 2 months and had no problems.
Loctite now makes double-sided tape u can pick up @ Walmart for like $6 a roll. It's ridiculously strong. It was like 45-50 degrees out when I did mine so I used a heat gun to warm it up a little. That lip isn't budgin' and I didn't need to use any screws!
