cld12pk2go
Girls From Your City - No Selfie - Anonymous Casua
- USA
subscribed
subscribed
so for the GT3071 turbo, what all needs to be done to the car for it to work well? im looking at getting it soon![]()
hey hey now, we've got almost 20,000 miles on our GT3071R stock motor mazdaspeed6 and all the rods are where they belong![]()
i thought 15psi daily and 18psi aggressive tune. don't hold me to that though.
Their shop car is the reason I'm considering not building the motor.... erg.
I'm sure you mentioned this before, but how many psi are you running daily? It's without meth correct?
jason currently runs the car at 18psi. the car is fitted with a snow performance methanol injection kit but has not been truly tuned to take advantage of it.
I copied this from elsewhere but heres the details on my car
We screwed up the solenoid install... there was some restrictor something or other that we didnt pull off the old turbo before i sent it off. Jordan at CPE and my tuner were on the phone, back and forth all day, After fixing the issues of the solenoid we then started getting our commanded boosts. We added and subtracted fuel and there was no problems...none. The timing was played with and we played with all sorts off other parameters... mostly centered around getting a smooth power curve.
A/F was great. We had added fuel intially down low and pulled some up top.... It stayed great all the way through the session... at least 20-30 pulls. A?F was in the 10.8-11.4 range after pulling it.. We didnt get much power by pulling fuel past that.
Final numbers for today were a heatsoaked 308whp and 320/trq at 16 psi tuned. Im a little disappointed but you have to remember that I was at about 260-270 on this dyno before. That means Ive gained about 40-50 whp with the manifold, inlet, and turbo running less psi.
Car is a rocket and I make power to redline. On the dynos I dont even start to fall until about 6400. On the other dyno in town I'd probably be around 325/340 based on previous runs, so dont be too disappointed with these numbers... Im mostly excited about the gains and the way the car feels. The BPV sounds like a sledgehammer now... its awesome. Turbo spool is VERY noticeable.
And again... huge.... is the a/f. Graph looks stock except for where we played. The fuel pump is working great, and I cant say enough about the standback and how great my tuner thought it was to use.
The guys at CPE and the standback should not be written off. **** anybody that gives me a hard time about it too.We adjusted fuel handily, timing, boost, pid control to smooth the curves and it worked.... Jordan spent most of the afternoon back and forth with Mark on the phone. Everything worked great once we sorted out our own mistakes.
All right.... ask away if you want too. And sorry I have no graphs, pictures, nada... they will be posted later. I was in a hurry to get out of there when they got done and my wife was pissed our first day back(from vacation).... I spent all afternoon with the car and was late getting home.
I think most of you know Im not making all this s*** up though![]()
sweet!
what kind of tires are you going to run after you shred these in a fit of joy?
kdw?
