- Cx5
Seems like all the concern and confusion is because the engines are delivered with the oil below the MAX line, and the stated capacity seems to yield a reading below the MAX line when changing.
That should not be a problem. Level is only a problem when it falls BELOW the MIN line, or above the MAX line. ANYWHERE in between [check when the engine has reached full operating temp and cooled off for 5 minutes] is fine. It does NOT have to be at MAX. I prefer mine to be a little below.
When changing oil, DO NOT fill all the way to MAX, because the oil you put in is cold and will expand when hot. A 5 qt jug should be fine. Next time you check it, you can adjust as necessary or if desired. Even if it's only halfway between the lines it's fine.
The exact level is not such a BFD.
My post was specific to the factory filled 2.5t being slightly overfilled per the stick. Not the 2.5na that reads in between the high and low holes with the recommend amount of oil.
Im just curious if other 2.5t owners are seeing the same thing.
