Greddy emanage timing control!
See, I need a solution to this thing!
I will check if theres another MAF compatible with our ECU.
I cant keep up with nice cars because it cuts me while accelerating hard.
Is not a cut as when reaching 140mph, is a very noticeable loose of power and a lean reading in the A/F
Who has base maps for the E-Manage? also 4 turboge why quit with the Haltech when it has more room to grow then the greddy.
There are no base maps, when you install the unit it is "zeroed" so that you can go +/- from there. I'm pretty much done with the Haltech right now, I finalized my timing and fuel maps for up to 8psi and it runs well.... now its on to the next form of management..
paulmp3 said:
why not up keep using the haltech?
cuz...he is bored....... after the emanage.....he is going to fabricate a series of vacume tubes and transistors and create his own piggy back.
You like the spicy pie huh? ... anyways.. yes I will combine various methods of the time space continuum into a piggy back that will allow me to go back in time and erase the mistakes I have made and also bet on sports games.
