So anyway info you want:
Motor is FS-DE, bore 83mm, stroke 92mm
Issues with internals: Rod fatigue if boosting basically above 10 psi, Motors MIGHT be rpm sensitive as well. I believe there was one failure from 7200+ rpm's with stock rods on the dyno.
Nothing fancy to put in internals, we have a closed deck block, so very strong from that standpoint, and the head gasket is very strong and can hold into the 20's for psi, and detonation too.
Engine management options: DSM Convert has an airflow Logisitcs thing that works good I guess, but I know nothing about... MP Nick sell the MPI Tuner which is around 6-800 I believe and works well as a piggyback. I sell the Microtech standalones which are about 1150 shipped and work well, the Haltech EMS is being used by some and I believe runs around 1500, then there is the AEM which is all out and runs around 2200 and is sold by Mental Addiction. There is also uni-chip and a few others available there.
NA power I think people have been able to net 150+ at the wheels... but not sure... FI we are pushing to the 400 mark here.. but found out that at about 300 whp you will blow 3rd gear in the tranny... solutions are being worked on. Otherwise transmission is good but people early on broke shift forks from shifting abuse, but haven't had that in a while.
LSD's are available... the Mazdaspeed LSD works very well and is super cheap (450 bucks) but should be welded for increased strength if you are going to go high horsepower or like to beat on the car and aren't good about stopping wheel hop. The Quaife LSD can go in our transmission as well but runs around 900 to 1100.
Motor mounts are a big improvement. AWR offers solid front and rear mounts. I offer casting of the motor mounts to get them to kill wheel hop as well..
Any questions you have just shoot me a pm or post here and I'm happy to help!
Later,
Steve
NSN Motorsports, LLC
